Al_Hoff
Apr 05, 2022Aspirant
Vivox (unity) Game Voip unable to connect LBR20 , what settings? LBR20 using LTE
Hey guys, I have been using a franklin tmobile hotspot without too much issue. Of course upgrading to the LBR20 has shown great performance increases. However while using the LBR20 I am running into ...
KevinLiT
Apr 05, 2022NETGEAR Moderator
Hello Al_Hoff,
I understand that you are not able to use Vivox for in-game voice communications on your LBR20. However, you are able to use Vivox with a VPN. This could be due to the region configuration on your LBR20.
Please follow the steps below to resolve your issue:
- First, Select ADVANCED > Advanced Setup > Wireless Settings.
- Then, Navigate to the "Region" menu to change your region.
(This option is not available for all regions)
For more information on the LBR20 LTE region configuration please visit the following link and navigate to page 86:
https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_UM_EN.pdf
Please let me know if this helps!
Best,
Kevin
Community Team
Al_Hoff
Apr 06, 2022Aspirant
Hello Kevin, I navigated to wireless settings tab. The region already appears to be set to North America (I am in the USA) and the box is grayed out/un-selectable.
