Mnuzz
Jul 24, 2018Tutor
Vizio tv display slow speeds on wired and wireless with orbi cbk40
I purchased a cbk40 setup installed the cbr40 modem router and synced the satellite. All of my devices connected smoothly. I have a 100 mg service from cox. The devices include 2 iPhones,iPad,wireles...
Jul 24, 2018Guru - Experienced User
I would make sure the TVs FW is up to date.
Contact the TV mfr and ask for help and information regarding this. If other devices are working with the Orbi system and the TV isn't, this would be a TV issue.
Try the TV connected directly to the CBR40, not the satellite.
Try Disabling MIMO. You can disable Beamforming and see if this does anything different. I have this enabled on my system.
FW up to date on the Orbi system?
