mexiwi
Aug 20, 2018Tutor
VLAN tagging for TPG NBN
I have just had NBN connected here in Australia through iiNet which uses the TPG FTTC service.
It uses PPPOE and requires the WAN port to be set with a VLAN ID of 2 and priority of 0.
I ...
- Oct 27, 2018Hey mate it took me a couple hours last night but I've worked it out. You have to upgrade the firmware on the Orbi to the latest version. I had to put my D7000 in bridge mode (modem only) and then connect my Orbi to it in AP mode. This let the Orbi connect to the internet enough to download and install the firmware. The new firmware let's you change the VLAN ID to 2 which is required for TPG HFC or similar NBN. The old firmware just made it stick to a VLAN ID of 10 no matter how many times you tried to change it. Once it was updated I just went to the Orbi, Advanced Settings and then went to the VLAN section and set the "Set VLAN by group" option for internet to VLAN ID 2. Then it worked! I'm now able to use the Orbi connected directly to the NBN. No more intermediate routers. Hope this helps!
Aug 20, 2018Guru - Experienced User
