scornwell
Sep 27, 2017Apprentice
VLAN tagging still broken in 2.0, after months of working with support I'm done.
After the better part of three months, hours on the phone to support, multiple emails chasing them up for progress and dozens of attempts at getting some communication here, the end result is Netgear...
scornwell
Oct 05, 2017Apprentice
Are you using Orbi in AP or router mode?
And have you tried rebooting to see what happens?
I'm glad it worked for you, but either way, the support si still a joke. I still have an open ticked with netgear, they haven't responded in weeks.
JoelM3d
Oct 05, 2017Tutor
My Orbi is set up as a router, not an AP.
I originally used my isp's modem to do VLAN tagging but when I updated my firmware to 1.12.0.18 I saw that there was VLAN tagging in the advanced settings. I unplugged my isp's modem and turned on VLAN tagging with appropriate settings (201 for Centurylink) and it just worked.
I've since rebooted a few times, installed 2.0.0.72 firmware and did a factory reset and loaded up my old settings and everything worked as expected.
No comment on support as I've yet to need it.
Isn't it a moot point anyway? You said yourself that you already moved on...
