fabridges
Mar 27, 2020Aspirant
Vodafone NZ Fiber and Orbi80
Hi - i have read through other posts, but get lost. Have a stanfard Chorus Firbe Modem and a Vodafone router - techicolor ultra hub. When setting up the Orbi80, i get wifi signal, but no inte...
- Mar 27, 2020
Sometimes sequence is important. i.e.
- Power off the Orbi and modem.
- Connect the Orbi WAN (yellow) port to the only ethernet port on the modem.
- Power on the modem and let it stabilize (this can take 2-3 minutes)
- Power on the Orbi router. It should go through a sequence of steps:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
i.e. the "Ring Light" at the top should be white for a few minutes (computers are not as fast as we want them to be)
Then, the Ring Light should go out. "No Light" is correct. - At this point, the Orbi should have created the WiFi network and be read for login.
The WiFi name (SSID) was originally ORBI80, but you may have changed it during the original setup (did you?)
The WiFi password was originallly what is printed on the product label, but you may have changed that as well (did you?) - At this point, you should be able to connect a WiFi device to the Orbi (phone, tablet, laptop, etc.)
A web browser on the device should have internet access.
I might be mistaken, but I seem to remember that "routerlogin.net" has been used for Netgear routers for a long time, and that perhaps the Orbi name is "orbilogin.net". If it doesn't respond to that, you need to look at the IP information on your device. There should be the IP address of a "gateway", which is the Orbi router. You can open a web browser to that, i.e. "http://<ip of gateway>" (no quotes)
Until the router is working correctly, I would not attempt to power up any satellites.
CrimpOn
Mar 27, 2020Guru - Experienced User
fabridges wrote:Have a standard Chorus Fibre Modem and a Vodafone router - technicolor ultra hub.
When setting up the Orbi80, i get wifi signal, but no internet connection.
"ORBI80" is the name of the WiFi name that the Orbi will broadcast, with the password being what is printed on the label.
It would help to know the specific model number of the Orbi router, which is also on the label.
How is this Orbi being set up? (Orbi "app" or using a Windows or Mac computer)?
Is it correct that the yellow (WAN) jack on the Orbi has been connected to an ethernet jack on the Vodafone router?
