Siberiantiger6
Dec 21, 2018Tutor
Voice over Wifi
I had a Zyxel P8702n and had to replace it because it died. So i wanted more functions and bought NetGear Orbi RBK40-100PES
Before i replaced the Zyxel box, voice over Wifi worked like a charm ...
Siberiantiger6
Dec 21, 2018Tutor
I did set the phone in flight mode, and then activated wifi and tried making a call. The phone just asks me to turn off flight mode to make the call.
ekhalil
Dec 21, 2018Master
Please set to flight mode, activate wifi and give the phone some time to attach to VoWifi GW. Only when you see that the phone is attached to VoWifi you can make a call.
Please also check that you have WMM activated in Orbi as follows:
Also please tell us a bit about your network setup.
- Siberiantiger6Dec 21, 2018TutorThe wmm settings is already set.
I have used WiFi on my phone all time at home since I got the new router a few days ago and never seen the "wifi tale" on my phone with Orbi as the router.- ekhalilDec 21, 2018Master
I have used WiFi on my phone all time at home since I got the new router a few days ago and never seen the "wifi tale" on my phone with Orbi as the router.Please try the following:
- As a test, Please disable Circle if you have it activated.Few mentioned that they had issues with VoWifi with Circle.
- What DNS are you using? As a test please try to change to Google's DNS 8.8.8.8 and 8.8.4.4 as follows:
Do you use any port forwarding?
- Siberiantiger6Dec 21, 2018TutorWith Disney Circle disabled, Voice over Wifi works immediately. I did not change the dns and have no port forwarding.
Is there a setting in Disney Circle I can set to make it work with voice over wifi?
