Siberiantiger6
Dec 21, 2018Tutor
Voice over Wifi
I had a Zyxel P8702n and had to replace it because it died. So i wanted more functions and bought NetGear Orbi RBK40-100PES
Before i replaced the Zyxel box, voice over Wifi worked like a charm ...
Siberiantiger6
Dec 21, 2018Tutor
Yes, I applied the settings (disable Circle) and it is still disabled. I will try enable and disable again to see if voice over wifi works again. That was the only setting I made in the router
ekhalil
Dec 21, 2018Master
Sometimes it's tricky to disable Circle once it's activated! It seems that Circle installs some sort of plugin in Orbi that's not easy to remove.
Try powr on and off after you disable Circle. This might help.
