Siberiantiger6
Dec 21, 2018Tutor
Voice over Wifi
I had a Zyxel P8702n and had to replace it because it died. So i wanted more functions and bought NetGear Orbi RBK40-100PES
Before i replaced the Zyxel box, voice over Wifi worked like a charm ...
ekhalil
Dec 21, 2018Master
Or go to Circle and remove the phone from all groups or follow the instructions in the link (https://support.meetcircle.com/hc/en-us/articles/115001381471-Problems-with-Voice-Calling-over-Wi-Fi) to allow VPN & Proxies for all phones.
Siberiantiger6
Dec 21, 2018Tutor
This is very strange.
The VPN setting was set to allowed (probably me that have set this the first time I set up the device/router) so that was never the reason. And now, after having enabled Circle again and saved/applied the voice over wifi works again. And this time it looks like it stays like that.
I will test more tomorrow. Thanks for the fantastic help so far. I will update this thread as soon as I can confirm what solved this case.
- ekhalilDec 21, 2018Master
Great. Please keep us posted!
- ekhalilDec 22, 2018MasterI think I know what happened. Once you disabled Circle it will stay disabled until you set it up again from the Circle app from scratch again.
- ekhalilDec 25, 2018Master
Siberiantiger6 wrote:
I will test more tomorrow. Thanks for the fantastic help so far. I will update this thread as soon as I can confirm what solved this case.I'm interested to know if both Wifi Calling and Circle are working now? :)
- Siberiantiger6Jan 08, 2019Tutor
The VoiceOverWifi works and Disney Circle also work.
- ekhalilJan 08, 2019MasterGlad that all is working for you now. Thanks for letting us know.
