Siberiantiger6
Dec 21, 2018Tutor
Voice over Wifi
I had a Zyxel P8702n and had to replace it because it died. So i wanted more functions and bought NetGear Orbi RBK40-100PES
Before i replaced the Zyxel box, voice over Wifi worked like a charm ...
Siberiantiger6
Dec 21, 2018Tutor
This is very strange.
The VPN setting was set to allowed (probably me that have set this the first time I set up the device/router) so that was never the reason. And now, after having enabled Circle again and saved/applied the voice over wifi works again. And this time it looks like it stays like that.
I will test more tomorrow. Thanks for the fantastic help so far. I will update this thread as soon as I can confirm what solved this case.
ekhalil
Dec 25, 2018Master
I'm interested to know if both Wifi Calling and Circle are working now? :)
- Siberiantiger6Jan 08, 2019Tutor
The VoiceOverWifi works and Disney Circle also work.
- ekhalilJan 08, 2019MasterGlad that all is working for you now. Thanks for letting us know.
