PWBerry
Feb 09, 2019Guide
Voice over Wifi
Cell service in my area is bad, so I use voice over WiFi on my iPhone. My internet service max speed is only 12 MBS, very slow. Once I switched to using the RBK50 mesh router, about 50% of the times t...
Chuck_M
Feb 09, 2019Mentor
A couple of questions for you:
What is the speed test reporting for you?
Under advanced setup | wireless settings
Can you tell us what those are set to right now? (What boxes are checked and not checked?)
Finally, what version of firmware are you using>?
- PWBerryFeb 10, 2019Guide
Answer to your questions:
What is the speed test reporting for you? very slow.. Download = 6.78 mbps Upload = 1.46 mbps
Bold items are checked under these sections:
Advanced Wireless Settings (2.4GHz b/g/n)
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Enable WMM (Wi-Fi multimedia) settings
Advanced Wireless Settings (5GHz 802.11a/n/ac)
Enable SSID BroadcastEnable WMM (Wi-Fi multimedia) settingsBackhaul Topology
Enable Daisy-Chain TopologyFinally, what version of firmware are you using>? V2.2.1.210
- Chuck_MFeb 10, 2019Mentor
Regarding daisy chain, are your satellites in serial or parallel (e.g. are they in a line or in a hub and spoke from router)
- PWBerryFeb 11, 2019GuideI’m not sure how to tell. I used the default setting for Daisy Chain. The main Orbi router to connected to the AT&T modem/router which has wireless turned off. The Orbi satellite is connected wirelessly to the main Orbi router.
