PWBerry
Feb 09, 2019Guide
Voice over Wifi
Cell service in my area is bad, so I use voice over WiFi on my iPhone. My internet service max speed is only 12 MBS, very slow. Once I switched to using the RBK50 mesh router, about 50% of the times t...
Feb 19, 2019Guru - Experienced User
Have you tried the Orbi in AP mode with the ISP modem/router?
PWBerry wrote:
The ISP router/modem is an AT&T Arris NVG589. It was my main wireless router until I purchased the Orbi. Then I turned off the wifi setting in the ISP router since I was now using the Orbi wifi. I still need the ISP router to connect to AT&T.
PWBerry
Feb 19, 2019Guide
I have not tried to setup the Orbi in AP mode. If I do change it, do I need to try anything else as well on either the Orbi or ISP router? Also, do you think changing the Orbi to AP mode would affect the Ooma VOIP quality? I'll be traveling away from home for a few days and will try what you recommend when I return later this week.
- FURRYe38Feb 19, 2019Guru - Experienced User
I would change the configuration back to default settings on the ISP router if you configured any DMZ or IP Pass thru as these will not be needed for the Orbi in AP mode. Just ensure also that the wifi radios ON the ISP router are disabled.
I would ensure Beamforming and MIMO is enabled.
Test Daisy Chain enabled and disabled to see if there are any differences.
- PWBerryFeb 19, 2019Guide
Just to confirm:
Reset ISP router to factory defaults
Turn off wifi on ISP router
Turn off DMZ and IP Pass thru on ISP router
Turn on AP mode on Orbi
Regarding Beamforming and MIMO being enabled, is that on the Orbi or ISP Router?
Test Daisy Chain enabled and disabled to see if there are any differences, is that on the Orbi or ISP Router?
PWBerry wrote:
Just to confirm:
YES.
Regarding Beamforming and MIMO being enabled, is that on the Orbi or ISP Router? Orbi
Test Daisy Chain enabled and disabled to see if there are any differences, is that on the Orbi or ISP Router? Orbi
