MV007
Nov 17, 2021Follower
Voice Sync delays on some websites!
Hi All, I have an RBR50 and RBR50S and ultimately for the last few years it has been working absolutely fine however recently I have been having issues with BBC iPlayer and some websites where th...
Nov 17, 2021Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
