STEPHANE77700's avatar
May 24, 2019
VOTRE CONNEXION A CE SITE N EST PAS PRIVEE
Hello everyone,   I need help please. Since the internet wifi network at my home, unable to connect to the site, the following message appears "your conexion is not this site is not private". While w...
  • FURRYe38's avatar
    May 27, 2019
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    What WPA security modes are you using? WPA2 and AES is recommended.
    Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
    STEPHANE77700 wrote:
    Hello everyone,   I need help please. Since the internet wifi network at my home, unable to connect to the site, the following message appears "your conexion is not this site is not private". While when I'm on the wifi of my livebox it works very well. Maybe have a solution please?   Model: Orbi AC2200 RBR20 Tri-band WiFi Router
