STEPHANE77700
May 24, 2019Initiate
VOTRE CONNEXION A CE SITE N EST PAS PRIVEE
Hello everyone, I need help please. Since the internet wifi network at my home, unable to connect to the site, the following message appears "your conexion is not this site is not private". While w...
- May 27, 2019
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? WPA2 and AES is recommended.Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
STEPHANE77700 wrote:Hello everyone, I need help please. Since the internet wifi network at my home, unable to connect to the site, the following message appears "your conexion is not this site is not private". While when I'm on the wifi of my livebox it works very well. Maybe have a solution please? Model: Orbi AC2200 RBR20 Tri-band WiFi Router
STEPHANE77700
May 28, 2019Initiate
Bonjour ,
Merci beaucoup pour vos réponse, l'assistance téléphonique à résolu le probleme.
Belle journée
May 28, 2019Guru - Experienced User
Enjoy. :smileywink:
