Dec 20, 2019Guru - Experienced User
Voxels FW available for 50 series Orbi only available.
Any one interested or users with Orbi that have units outside of there warranty period, can give Voxels FW for Orbi 50 series systems only, a try:
https://www.snbforums.com/threads/custom-firmware-...
SW_
Dec 20, 2019Prodigy
(a) To set a separate SSID for the 5 GHz network on your Orbi RBR:
• From telnet/ssh console run
Code: nvram set wla_ssid="NAME OF YOUR 5GHZ NETWORK" nvram set allow_diff_ssid=1 nvram commit
• Reboot your RBR and RBS
• Set “allow_diff_ssid” in nvram to “0” to disable separate SSIDs.
NOTE:
It is not recommended to separate the SSIDs.
Your connection could be unstable.
Under your own risk.
Nice addition, but still risky to enable it seems.
- FURRYe38Dec 20, 2019Guru - Experienced User
Ya still has to be done thru telnet.
- JetdriveDec 21, 2019Luminary
Anyone try this? Are there any new features added that stock NG firmware doesn't have?
- FURRYe38Dec 21, 2019Guru - Experienced User
I have the prior version loaded on my RBK50. Working just find.
Read the release notes to see what he puts in. There are 3 threads over there, each with what he's done to each version. Or find the notes over where you can download the files from. He supports separation of SSIDs however it's not in the UI. All done with telnet. He does not really recommnend separation though. For those who want it, it's there.
You can load and try it out. If not, just re-load stock FW and your back to NG FW. Easy to migrate back and forth.
