Dec 20, 2019Guru - Experienced User
Voxels FW available for 50 series Orbi only available.
Any one interested or users with Orbi that have units outside of there warranty period, can give Voxels FW for Orbi 50 series systems only, a try:
https://www.snbforums.com/threads/custom-firmware-...
Oct 22, 2020Guru - Experienced User
New version of Voxel custom firmware build: v9.2.5.2.6SF-HW
Changes (vs 9.2.5.2.5.1SF-HW):
1. Toolchain: Go is upgraded 1.14.7->1.15.3.
2. Toolchain: binutils version is upgraded 2.35->2.35.1.
3. Toolchain: -finline-functions compiler option is added to GCC.
4. Kernel level acceleration (-O2, -march=armv7-a -> -mcpu=cortex-a7, -finline-functions, etc.).
5. wireguard package is upgraded 1.0.20200729->1.0.20200908.
6. Change kernel config and OpenSSL 1.1.1 to allow using dynamic devcrypto and afalg engines (HW version).
7. OpenSSL v. 1.1.1 package is upgraded 1.1.1g->1.1.1h.
8. OpenSSL v. 1.0.2 package: change default config directory.
9. Fix Smart Lock icon issue (WebGUI).
10. jansson package is upgraded 2.12->2.13.1.
11. libjson-c package is upgraded 0.14->0.15.
12. expat package is upgraded 2.2.9->2.2.10.
13. nano package is upgraded 5.2->5.3.
14. Change SAMBA config generation (for Android/iOS gadgets, issue reported by Rustypouch).
15. Make an order in samba36 Makefile.
16. logrotate package is upgrader 3.15.0->3.16.0.
17. cifs-utils package is upgraded 6.10->6.11.
18. iperf3 package is upgraded 3.8.1->3.9.
19. Fix proftpd issue: display size of large file (thanks to R. Gerrits).
P.S. My README.1st and QuickStart.txt:
(!) IMPORTANT NOTE: it is strongly advised to update to the stock firmware 2.5.2.4 before flashing this version. If your on a older stock version than v2.5.2.4, then you'll need to update to stock v2.5.2.4 first before you apply v9.2.5.2.6SF-HW.
If you are already using Voxel FW and up to date, then this "update to the stock firmware 2.5.2.4" is not needed of course.
The link is:
https://www.voxel-firmware.com
standarduser73
Oct 28, 2020Tutor
Does moving to Voxel's firmware give any more info for bandwidth utilization? The stock Orbi stuff tells me the aggregate of usage, but not per device.
I am interested in per device usage, so I wonder if Voxel provides that.
