Dec 20, 2019Guru - Experienced User
Voxels FW available for 50 series Orbi only available.
Any one interested or users with Orbi that have units outside of there warranty period, can give Voxels FW for Orbi 50 series systems only, a try:
https://www.snbforums.com/threads/custom-firmware-...
Aug 03, 2021Guru - Experienced User
New version of my custom firmware build: 9.2.5.2.14SF-HW.
Changes:
1. Toolchain: binutils version is upgraded 2.36.1->2.37.
2. Toolchain: Go is upgraded 1.16.5->1.16.6.
3. QCA drivers/firmware are upgraded (integration from V2.7.3.22 stock).
4. wireguard-tools: add PresharedKey support to WireGuard client.
5. OpenVPN is upgraded 2.5.2->2.5.3.
6. curl package is upgraded 7.77.0->7.78.0.
7. proftpd package is upgraded 1.3.7a->1.3.7b.
8. gettext-full package is upgraded 0.19.8.1->0.21.
9. ethtool package is upgraded 5.12->5.13.
10. ipset package is upgraded 7.11->7.14.
11. e2fsprogs package is upgraded 1.46.2->1.46.3.
12. util-linux package is upgraded 2.37->2.37.1.
13. Change WebGUI logo.
14 Kernel: Use FSCACHE as a kernel module.
15. Host tools (e2fsprogs): is upgraded to 1.46.3.
P.S. My README.1st and QuickStart.txt:
(!) IMPORTANT NOTE: it is strongly advised to update to the stock firmware 2.5.2.4 before flashing this version. If your on a older stock version than v2.5.2.4, then you'll need to update to stock v2.5.2.4 first before you apply v9.2.5.2.6SF-HW.If you are already using Voxel FW and up to date, then this "update to the stock firmware 2.5.2.4" is not needed of course.
The link is:
https://www.voxel-firmware.com
CrimpOn
Installed fine for me. LIke his Logo on the home page.
