Mercuryaces
Apr 12, 2019Aspirant
VPN and Orbi
Hey guys I'm having some trouble figuring out if vpns work with the orbi mesh system. I've got an orbi, and would like to subscribe to tunnel bear as my VPN service. Are these two compatible? Do I nee...
Apr 12, 2019Guru - Experienced User
I would ask the Mfr of that VPN to see if Orbi is compatible.
NG already uses OpenVPN I believe on there systems.
- MercuryacesApr 12, 2019AspirantIf you could elaborate more. I'm just a bit confused. I don't want to install tunnel bear on the router itself, just on my PC. Would doing this hide my activity or do I require router support? In new to vpns but was under the impression it wasn't router dependent.
- plemansApr 12, 2019Guru - Experienced User
if you're installing it to your computer and just want it on there, it doesn't really matter what router you're running. it'll vpn fine.
If you're wanting it for all devices, then you need a compatible vpn provider.
