NLok
Oct 29, 2018Aspirant
VPN bypass not working in Orbi RBK22
When I connect to my company VPN from home, I don;t get the DNS from work. My admins at work keep asking to set VPN bypass on my wifi router but there is no setting like that available. My previous r...
Blanca_O
Nov 04, 2018NETGEAR Employee Retired
Hi NLok
May I request for the following information:
- What is the exact error message when trying to connect?
- Was this working before using older firmware version?
- Can you also describe your network setup?
Blanca
Community Team
NLok
Nov 05, 2018Aspirant
No error, when I try to ping my companies Hosts (after conencting to Cisco VPN) it sends request to internet instead of local DNS and hence I cannot connect to company resources. I have to turn off the umbrella client and then I get local DNS resolution.
It was never working since day one of this router purchase. It was working with my D-Link router with no special setup.
I have Spectrum internet which comes to their Modem setup in bridge mode, Orbi router connected to 1 port of the Modem.
- FURRYe38Nov 05, 2018Guru - Experienced User
Something to try, set the ISP modem back to router mode, then try using the Orbi in AP mode to see if the problem continues.
You can also try setting the Orbi as router while the ISP modem is in router mode and place the IP address the Orbi gets from the modem into the modems DMZ and see if the problem continues.
- NLokNov 08, 2018Aspirant
Will try that tomorrow
- Blanca_ONov 13, 2018NETGEAR Employee Retired
Hi NLok
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
- NLokNov 13, 2018Aspirant
Had to abandon my testing as my ISP said router mode will cost me $5 per month. Also, just for testing I could not connect to the router/modem so they told me to turn in my router/modem and get the new modem with just 1 port/WAN which is in router mode by default etc. So will try that later.
