modcookieparty
Mar 19, 2020Aspirant
VPN Client - Can't Connect
I have been unable to connect to my work's servers through a VPN on ORBI. If I turn off DHCP then it connects but the ORBI systems doesn't work - any ideas to fix this?
CrimpOn
Mar 19, 2020Guru - Experienced User
modcookieparty wrote:I have been unable to connect to my work's servers through a VPN on ORBI. If I turn off DHCP then it connects but the ORBI systems doesn't work - any ideas to fix this?
Perhaps you could provide more information about the situation. Are we talking about:
- My work has servers and requires me to use VPN software to reach them.
I have VPN software on my computer and unable to connect. - My work has an Orbi router and servers behind the Orbi, so I need to use a VPN to connect to the Orbi and then reach the servers.
DHCP has to be turned off on what? (my computer? the Orbi?)
- modcookiepartyMar 19, 2020Aspirant
I have an Orbi at home and am trying to use a client VPN for connecting to my work servers. I can connect to the VPN on my Windows laptop but can't connect to my files at work. I turned off the DHCP setting on ORBI which allowed me through to my work drives but caused issues with every other device in the house. Thanks for the help.
- CrimpOnMar 19, 2020Guru - Experienced User
The computer running VPN client software is connected to the Orbi, correct?
Did you set a static IP address on the computer?
Yes, without a DHCP server somewhere on the network, every device will be unable to get an IP address and simply will not function.
The computer running VPN client software is connected to the Orbi, correct? Correct.
Did you set a static IP address on the computer? I did not. Would this help? Interesting thing is that I can connect to one server but not the one I need to connect to. My IT guy says it's all on my side.
