quaningeneva's avatar
quaningeneva
Apprentice
May 14, 2017
VPN Client Devices attached to Orbi
Under attached devices in the Orbi menu, how can I see which VPN devices are connected to the Orbi?  For example, this feature is available on the R7000.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Orbi supports TAP mode VPN so devices connecting in TAP mode will show under attached devices. If using TUN mode, devices encapsulate IPv4 or IPv6 (OSI Layer 3) so can’t display in the attached devices list
    DarrenM
