ernestvdh
May 15, 2020Aspirant
vpn dienst
iemand ervaring met vpn , zoals nordvpn of express vpn? werkt dat goed met netflix? welke heeft de voorkeur en waarom? ghr ernest
ernestvdh
May 16, 2020Aspirant
Hi,
Thnx for your mail.
Vpn via router doesn't work , I know.
But I was wondering, which vpn is beter, while installed local on my Imac or Iphone; so that I can stream Netflix to my Apple Tv.
Which vpn do you prefer?
kind regards,
ernest.
CrimpOn
May 16, 2020Guru - Experienced User
Alas, I do not use a VPN, so I have no opinion. There are many comparison reviews.
Sorry.
