Abe12
May 20, 2019Aspirant
VPN for Orbi RBK23?
Hello,
Has anyone had luck setting up a VPN for the Orbi RBK23 router? Two of the more highly recommended VPNs (ExpressVPN and Nord VPN) are not compatible. Thanks!
May 20, 2019Guru - Experienced User
- Abe12May 20, 2019Aspirant
Thanks! I'm not sure I can follow all of the technical elements in your setup--and I'm using a Mac and a PC--but it is good to know that it might be at least possible. I keep seeing that OpenVPN is not supported by Orbi. But it looks like you're running the VPN through your device rather than the router. Is that right? Sorry for my technical ignorance. I very much appreciate your help!
