mayhemxtc
Jan 24, 2019Tutor
VPN on Orbi without DDNS
I have an RBR20 system, according to its web page: a router & 2 sattelites.
I saw a previous post with the same title that says it "should be no problem" to set up the vpn without setting up t...
mayhemxtc
Jan 24, 2019Tutor
I have a dynamic dns provider which points my domain at whatever IP my ISP assigns me, and a cron job that checks it every 5 mins and updates the dns if need be.
The problem is that I dont want to have to use one of the dynamic dns providers that are preconfigured on the router.
I could of course run my own openvpn server, but it would be nice to use the builtin functionality without being forced to use netgears preferred suppliers
randomousity
Jan 25, 2019Luminary
Yeah, I get that, but I don't think it's feasible for them to make the firmware work with arbitrary DDNS providers.
- mayhemxtcJan 26, 2019Tutor
I understand that and am not expecting them to. I just want tp be able to enable the vpn without entering ddns provider details at this point.
Whilest you probably wouldnt want to run a vpn without it, there are concievably times when you would. Such as in my case, or if you have a static IP from your ISP, to name two.
The reason I dont want to change is that I got my bought & paid for .co.uk domain name transfered to my current provider, whereas the provider options given dont provide the services I want/need or want a lot of money for it
I havent had a reply from Netgear support, so will proceed with setting up vm for this today.
Thanks for your help
- mrmstnJan 26, 2019Guide
TL;DR: Netgear won't help (maybe because they partnert up with no-ip). I think this restriction defentily should not exist. And yeah, I also got my own domain and more or less a static IP, but given by dhcp.
Haha - I also opend a support ticket on that one - I also posted some things on here: https://community.netgear.com/t5/Orbi/Strange-requirement-for-VPN-activation/m-p/1694642
I also posted a replay from the support: https://community.netgear.com/t5/Orbi/Strange-requirement-for-VPN-activation/m-p/1694654/highlight/true#M50668They just told me it's not possible, I need DynDNS if don't have a static IP, I should look into https://kb.netgear.com/23944/I-have-a-Nighthawk-router-what-is-Dynamic-DNS-and-why-should-I-set-up-a... why I need DynDNS.
Currently I'm trying to build my custom rom, based on the firmware from https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL but it looks some packages get lost somewhere (I flashed the hole thing on my RBS20 Satelite as a test and it looked like the wifi driver went missing, so I'm currenty back on the Stock Rom.
So.. If anyone has e Idea or knows something more about openWRT then a newbie like me, just PM me - I'm currently using the docker container from here: https://hub.docker.com/r/cybertanyellow/qsdk-buildroot it comes with a gcc 4.8.4 compiler, instead of the expected 3.2. I also tried the 3.2 but that one didn't work ether...
