mayhemxtc
Jan 24, 2019Tutor
VPN on Orbi without DDNS
I have an RBR20 system, according to its web page: a router & 2 sattelites.
I saw a previous post with the same title that says it "should be no problem" to set up the vpn without setting up t...
randomousity
Jan 25, 2019Luminary
Yeah, I get that, but I don't think it's feasible for them to make the firmware work with arbitrary DDNS providers.
mayhemxtc
Jan 26, 2019Tutor
I understand that and am not expecting them to. I just want tp be able to enable the vpn without entering ddns provider details at this point.
Whilest you probably wouldnt want to run a vpn without it, there are concievably times when you would. Such as in my case, or if you have a static IP from your ISP, to name two.
The reason I dont want to change is that I got my bought & paid for .co.uk domain name transfered to my current provider, whereas the provider options given dont provide the services I want/need or want a lot of money for it
I havent had a reply from Netgear support, so will proceed with setting up vm for this today.
Thanks for your help
- mrmstnJan 26, 2019Guide
TL;DR: Netgear won't help (maybe because they partnert up with no-ip). I think this restriction defentily should not exist. And yeah, I also got my own domain and more or less a static IP, but given by dhcp.
Haha - I also opend a support ticket on that one - I also posted some things on here: https://community.netgear.com/t5/Orbi/Strange-requirement-for-VPN-activation/m-p/1694642
I also posted a replay from the support: https://community.netgear.com/t5/Orbi/Strange-requirement-for-VPN-activation/m-p/1694654/highlight/true#M50668They just told me it's not possible, I need DynDNS if don't have a static IP, I should look into https://kb.netgear.com/23944/I-have-a-Nighthawk-router-what-is-Dynamic-DNS-and-why-should-I-set-up-a... why I need DynDNS.
Currently I'm trying to build my custom rom, based on the firmware from https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL but it looks some packages get lost somewhere (I flashed the hole thing on my RBS20 Satelite as a test and it looked like the wifi driver went missing, so I'm currenty back on the Stock Rom.
So.. If anyone has e Idea or knows something more about openWRT then a newbie like me, just PM me - I'm currently using the docker container from here: https://hub.docker.com/r/cybertanyellow/qsdk-buildroot it comes with a gcc 4.8.4 compiler, instead of the expected 3.2. I also tried the 3.2 but that one didn't work ether...
