BlankAlpha
Jan 02, 2020Aspirant
VPN Places Client on Different Subnet
My client (in this case an android phone) gets placed on a different subnet than my DHCP when VPN'd through the RBR50. The RBR is +1 my ip from 192.168.1.10 to 192.168.2.10 Is there a way to ...
ekhalil
Jan 02, 2020Master
You can't change the VPN address range in the "original" Orbi (there is a workaround in the Orbi AX to change the subnet).
What issues do you have that you think are caused by the different subnets?
BlankAlpha
:'( That is a sad day.
It'll just require me to change iptables for a few different device to manage this exception.
I wonder if they'll encorporate that workaround into the OG Orbi.
Here is hoping!
Thanks for the update!!
