Mdomke63
Aug 28, 2019Aspirant
VPN Router behind Orbi
Previously I had been using Apple Express router, with a Netgear r7000 router behind it as a dedicated VPN router. Doing this allowed me to choose which network I wanted to be on because we serve ou...
- Aug 28, 2019
The R7000 and RBR share the same default IP address of 192.168.1.1, so you may want to change the R7000's default IP address to 192.168.70.1. Then see if the R7000 shows up...
Mdomke63
Thanks for taking the time to help me. I don't have a lot of experience in this field, so you may have to coach me a bit more. The only location that I can find DMZ is under Advanced/Setup/WAN Setup/Default DMZ Server via the web login and it appears that I need to enter the ip address. Not exactly sure what to do here. My Netgear R7000 receives a signal from the Orbi via cat5 cable.
ISP Modem is a Picotel Epon ONU, Model PU-E810
My Setup is as follows:
Picotel ISP Modem>Orbi RBR50>NG R7000 (Dedicated VPN). Both of these Wifi's would be working and I would simply select which Wifi system that I wanted to be connect to.
I have an excellent signal and speed with my Orbi, but can get no internet signal with my NG R7000.
Firmware is as follows:
Orbi RBR50
Firmware is V2.3.5.30
Netgear R7000 (Dedicated VPN router)
Firmware DD-WRT v24-sp2 (08/15/14) kongac - build 24865M
Thanks again!
Aug 28, 2019Guru - Experienced User
The IP address needed for the Orbi DMZ is the IP address that is given to the VPN device from the Orbi RBR, in your case the R7000. Look on the Orbis connected clients list to see where the R7000 shows up and the IP address its given will be listed here. I would set a IP address reservation for the R7000 so the address doesn't change on you.
- Mdomke63Aug 28, 2019Aspirant
Maybe we discovered the problem. My NG R7000 does not show up on the connected device list.
- FURRYe38Aug 28, 2019Guru - Experienced User
SUCCESS! When we changed the default IP on the R7000 it was able to connect to the internet! Thanks a ton!
Can't thank you enough. I had spent several days trying to figure it out and you did it in a few simple messages.
