Mdomke63
Aug 28, 2019Aspirant
VPN Router behind Orbi
Previously I had been using Apple Express router, with a Netgear r7000 router behind it as a dedicated VPN router. Doing this allowed me to choose which network I wanted to be on because we serve ou...
- Aug 28, 2019
The R7000 and RBR share the same default IP address of 192.168.1.1, so you may want to change the R7000's default IP address to 192.168.70.1. Then see if the R7000 shows up...
Aug 28, 2019Guru - Experienced User
Mdomke63
SUCCESS! When we changed the default IP on the R7000 it was able to connect to the internet! Thanks a ton!
Can't thank you enough. I had spent several days trying to figure it out and you did it in a few simple messages.
- FURRYe38Aug 28, 2019Guru - Experienced User
Awesome, Glad it's working now.
Enjoy. :smileywink:
Mdomke63 wrote:SUCCESS! When we changed the default IP on the R7000 it was able to connect to the internet! Thanks a ton!
