Nyirishman1877
Mar 19, 2019Aspirant
VPN ROUTER
I would like to know how I can setup Hidden Router device on my orbi system. When I connect it to one of the satellites. I lose internet connection. Am I doing something wrong and can anyone help m...
- Mar 20, 2019
Good to hear. Yes the change in operation will temporarily reboot the RBS so the change will take effect.
Glad it's working now.Please mark your thread as solved so others will know for future reference.
Enjoy. :smileywink:
Nyirishman1877 wrote:
I unchecked daiseychain feature and now the hidden router works. It did knock out the satellite it is hooked up to. But that was just part of the registration part and the satellite when back online
Nyirishman1877
Yes my Roku work wired to the orbi satellite. Satellite connects wirelessly to base. FW Is 2.3. something something lol
Mar 19, 2019Guru - Experienced User
So your trying to connect a VPN router to the satellite? Possible mis-configuration of this device. I would reference it's user manual to see if there is any info there.
You may need to use the Orbi DMZ for a VPN router behind the Orbi.
