Nyirishman1877
Mar 19, 2019Aspirant
VPN ROUTER
 I would like to know how I can setup Hidden Router device on my orbi system.  When I connect it to one of the satellites. I lose internet connection.  Am I doing something wrong and can anyone help m...
- Mar 20, 2019
Good to hear. Yes the change in operation will temporarily reboot the RBS so the change will take effect.
Glad it's working now.Please mark your thread as solved so others will know for future reference.
Enjoy. :smileywink:
Nyirishman1877 wrote:
I unchecked daiseychain feature and now the hidden router works. It did knock out the satellite it is hooked up to. But that was just part of the registration part and the satellite when back online
Mar 20, 2019Guru - Experienced User
Let us know if you get any progess on this.
I would like to know how I can setup Hidden Router device on my orbi system. When I connect it to one of the satellites. I lose internet connection. Am I doing something wrong and can anyone help me on how to properly set this up.
Also does it matter if i use a Cat5e or Cat6 wire for the Hidden Router device?
Thank you in advance
Nyirishman1877
Mar 20, 2019Aspirant
- FURRYe38Mar 20, 2019Guru - Experienced User
Enjoy. :smileywink:
