MaartenMH
Aug 03, 2019Aspirant
VPN server fails if upstream router uses 192.168.2.0/24 network
I spent some significant time this morning trying to get the VPN server in my RBR50 to work. I could connect to the VPN, but was unable to get any user data to transit the VPN. I finally figured...
ekhalil
Aug 03, 2019Master
You can’t have Orbi in Router mode (with DHCP functionality) and at the same time have you ISP modem (upstream router) providing DHCP functionality. This will leave you with 2 different networks and will cause you many issues.
If you want to keep Orbi in Router Mode (to provide VPN server functionality other features) you have to set the ISP router into bridge mode (pass through mode).
MaartenMH
Aug 09, 2019Aspirant
As long as you keep the networks from having overlapping IP ranges, and don't route broadcasts between them, it works just fine.
