Mgomez85
Jan 15, 2017Apprentice
VPN Service Help
Was wondering if anyone can help! My vpn service is not work at all! No matter which port I try udp or tcp! Open vpn can't seems too connect at all! I worked when I first got the orbi but now it's not...
MasterChief86
Jan 16, 2017Aspirant
ummm... you'll have to narrow down a bit. Is it working without a VPN? If not, try doing all of the following to narrow down to your pain point.
1. Try conencting your VPN to other devices, smartphones, tablets, other laptops/macbook
2. try using a different vpn like Ivacy, HSS, pure or any other you could find
3. Have you tried changing the numbers?
4. Double-check if all of your hardware is perfectly functional
Mgomez85
Jan 16, 2017Apprentice
2017-01-16 08:48:43 Server poll timeout, trying next remote entry...
2017-01-16 08:48:43 EVENT: RECONNECTING
2017-01-16 08:48:43 Contacting 69.122.xxx.xxx:12980 via UDP
2017-01-16 08:48:43 EVENT: WAIT
2017-01-16 08:48:43 SetTunnelSocket returned 1
2017-01-16 08:48:43 Transport Error: UDP connect error on 'xxxxxxxxxxx.ddns.net:12980' (69.122.xxx.xxx:12980): Network is unreachable
2017-01-16 08:48:43 Client terminated, restarting in 2...
2017-01-16 08:48:45 EVENT: CONNECTION_TIMEOUT [ERR]
2017-01-16 08:48:45 EVENT: DISCONNECTED
2017-01-16 08:48:45 Raw stats on disconnect:
BYTES_OUT : 350
PACKETS_OUT : 25
UDP_CONNECT_ERROR : 5
CONNECTION_TIMEOUT : 1
N_RECONNECT : 9
2017-01-16 08:48:45 Performance stats on disconnect:
CPU usage (microseconds): 45685
Network bytes per CPU second: 7661
Tunnel bytes per CPU second: 0
2017-01-16 08:48:45 EVENT: DISCONNECT_PENDING
2017-01-16 08:48:45 ----- OpenVPN Stop -----
thats my open vpn log file, of course where it says xxx is my info masking but of the life I don't understand why it's not won't connect when my dns works! đ©đ
