Mgomez85
Jan 15, 2017Apprentice
VPN Service Help
Was wondering if anyone can help! My vpn service is not work at all! No matter which port I try udp or tcp! Open vpn can't seems too connect at all! I worked when I first got the orbi but now it's not...
Mgomez85
Jan 16, 2017Apprentice
i do think think the ports are open also, now heres the thing, how do i open them? this service is done by the orbi router, i cant port forward 192.168.1.1, so thats where am confused.
st_shaw
Jan 16, 2017Master
When you go through the process of enabling the OpenVPN service on the Orbi, that should open the necessry ports. The details are written to a config file that needs to be loaded on your client machine.
I use OpenVPN on my Mac, iPad, Linux, and another router, but I haven't set it up on my Orbi, because I use it as an Access Point only.
- Mgomez85Jan 16, 2017Apprentice
here is a pic of my vpn settings i have tried changing port num, or even port types! when i switch to tcp and connected via my wifi (locally) it works if i get off it and switch to my cellphone LTE, it doesnt connect!! so something is blocking my ports as i suspected and yes i download the new config files each time i have changed the settings but still doesnt connect.
- st_shawJan 16, 2017Master
Sorry, I cannot see the picture for some reason. it's just a yellow triangle.
You can scan your system at the following website and see what ports are open. Try both UDP and TCP scans.
https://pentest-tools.com/network-vulnerability-scanning/tcp-port-scanner-online-nmap
If you want me to scan your ports and tell you if 1194 is open, send me an IM with your domain name.
Starting Nmap 6.00 ( http://nmap.org ) at 2017-01-16 23:01 EET
Initiating Ping Scan at 23:01
Scanning xxxxxxx.ddns.net (69.122.xxx.xxx) [4 ports]
Completed Ping Scan at 23:01, 0.12s elapsed (1 total hosts)
Initiating SYN Stealth Scan at 23:01
Scanning xxxxxxxx.ddns.net (69.122.xxx.xxx) [100 ports]
Discovered open port 23/tcp on 69.122.xxx.xxx
Discovered open port 8008/tcp on 69.122.xxx.xxx
Completed SYN Stealth Scan at 23:01, 2.36s elapsed (100 total ports)[+] Nmap scan report for xxxxxxxxx.ddns.net (69.122.xxx.xxx)
Host is up (0.093s latency).
Not shown: 89 closed portsPORT STATE SERVICE
7/tcp filtered echo
23/tcp open telnet
25/tcp filtered smtp
80/tcp filtered http
135/tcp filtered msrpc
139/tcp filtered netbios-ssn
443/tcp filtered https
445/tcp filtered microsoft-ds
3128/tcp filtered squid-http
8008/tcp open http
8080/tcp filtered http-proxy
Nmap done: 1 IP address (1 host up) scanned in 2.69 seconds
Raw packets sent: 113 (4.948KB) | Rcvd: 96 (3.944KB)
