Mgomez85
Jan 15, 2017Apprentice
VPN Service Help
Was wondering if anyone can help! My vpn service is not work at all! No matter which port I try udp or tcp! Open vpn can't seems too connect at all! I worked when I first got the orbi but now it's not...
Mgomez85
Jan 16, 2017Apprentice
Ok sorry was at work and I change those port with the intention thinking that maybe the defaults were blocked by my isp and it didn't work either, also my telnet to my router is turned off! I can confirmed that, those ports open is probably on a system that someone in my house is using, I live in NYC with 2 other houses above me (multi fam home) and each home have multiple devices and am sure someone in my fam have those ports open cause if i show u my port foward I have maybe 1-2 rules set and 1 device DMZ which is my security surveillance system so! I know those ports are not open via my router from me! Maybe on UPnP but even under my list those ports are NOT listed.... so yea
