Gibbous
Oct 04, 2021Tutor
VPN setup plus subnet Orbi router.
Can anyone give my detailed instrunctions on how to set up a VPN on my Orbi router? I have a third party VPN service that I currently pay for. Also, there are a few devices, out of my 21, that I don'...
- Oct 04, 2021
Gibbous wrote:
Despite this being a Netgear community post, can you give me a router name that does do what I need?I was incorrect about NordVPN. A basic account supports six devices.
There are a number of VPN clients that can be installed as a replacement for the manufacturer firmware.
ExpressVPN, for example, has a list on this page:
NordVPN's list is here:
https://nordvpn.com/flashrouters/ Notice that Netgear's routers are included, but the comment says "NO".
Internet searches will turn up lots of possibilities. (i.e. "Best VPN router" or something similar)
BUT.... BUT..... As far as having some devices use the VPN and others not use it, I have a premonition that no residential class router will do this.
CrimpOn
Oct 04, 2021Guru - Experienced User
Oh, dear. Orbi cannot do what you want.
Netgear routers include OpenVPN host capability, to allow devices in the internet to access the local LAN. It does not support VPN client.
The intention is to allow the owner to "get into" the local LAN when not physically attached to the LAN. I use OpenVPN, for example, to administer my Orbi remotely. People who host web or content servers often use VPN to manage them.
There is third party software for the RBR50 model that does support two versions of VPN client (OpenVPN and WireGuard). My impression is that setting a router in VPN client mode forces all internet traffic through the VPN.
What you want makes a lot of sense. My guess is that the only solution open to you is to subscribe to a 'package' deal that gives you more client licenses. (Do I remember correctly that NordVPN starts with 5?)
Sorry.
Gibbous
Oct 04, 2021Tutor
Thanks and Ugh.
- CrimpOnOct 04, 2021Guru - Experienced User
- GibbousOct 05, 2021Tutor
Thanks again, especially for the sense of humor.
- FURRYe38Oct 05, 2021Guru - Experienced User
Enjoy. 📡
