Gibbous
Oct 04, 2021Tutor
VPN setup plus subnet Orbi router.
Can anyone give my detailed instrunctions on how to set up a VPN on my Orbi router? I have a third party VPN service that I currently pay for. Also, there are a few devices, out of my 21, that I don'...
- Oct 04, 2021
Gibbous wrote:
Despite this being a Netgear community post, can you give me a router name that does do what I need?I was incorrect about NordVPN. A basic account supports six devices.
There are a number of VPN clients that can be installed as a replacement for the manufacturer firmware.
ExpressVPN, for example, has a list on this page:
NordVPN's list is here:
https://nordvpn.com/flashrouters/ Notice that Netgear's routers are included, but the comment says "NO".
Internet searches will turn up lots of possibilities. (i.e. "Best VPN router" or something similar)
BUT.... BUT..... As far as having some devices use the VPN and others not use it, I have a premonition that no residential class router will do this.
Gibbous
Oct 05, 2021Tutor
Thanks again, especially for the sense of humor.
Oct 05, 2021Guru - Experienced User
Enjoy. 📡
