heissmungo
Dec 19, 2018Aspirant
VPN stopped working after switch to Orbi
Ever since I switched from my Verizon router to the Orbi, both of the VPNs for my two jobs have stopped working. I don't think this is coincidence. One uses the built in VPN on Windows, the other t...
ekhalil
Dec 19, 2018Master
This can be caused by conflicts of IP addresses in your network.
Is the Orbi set in Router Mode? (check it in the web GUI under >> ADVANCED >> Advanced Setup >> Router/AP Mode).
If in router mode, then please make sure that you ISP router is bridged and does not provide any DHCP services. Otherwise you need to change Orbi to AP Mode instead.
- heissmungoFeb 11, 2019Aspirant
Thanks for the response. I am not using my ISP's router. My orbi is in router mode and plugged directly into the fios ONT via ethernet.
- ekhalilFeb 11, 2019Master
What DNS settings do you hve in Orbi. You can find the DNS settings in the web GUI (orbilogin.com) under >> BASIC >> Internet >>
