bittermanam's avatar
bittermanam
Follower
Apr 28, 2024
VPN will work with RBR50
Is there a VPN that will work with the Orbi RBR50? I know Proton VPN will not work
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Some VPNs require customised firmware on a router. As Netgear doesn't support third party firmware, you may not get much response here. If there is anyone with experience for the  RBR50 this probably the best place to ask.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    You might like to search there for messages related to your issue.
