beshoe25
Mar 10, 2018Initiate
Vulnerability Catalogue ID CVE-2017-14491
AVAST Network Scan shows this Vulnerability ID I have the latest firmware on both satillites and router by this persistes, any idea how to fix this issue? Is there a setting in the router that I can...
Mar 20, 2018Guru - Experienced User
Have you been in conact with NG support about this? Might see if there is any more information on this or ask about using a Beta FW.
beshoe25wrote:AVAST Network Scan shows this Vulnerability ID
I have the latest firmware on both satillites and router by this persistes, any idea how to fix this issue? Is there a setting in the router that I can change? Or am I at the mercey of Netgear to make a new firmware update?
Unknown
The device is vulnerable to hacker attacks. For more info see the corresponding vulnerability ID. An upgrade of the device's software/firmware may fix the issue.
Vulnerability ID:
IP Address:
beshoe25
Mar 20, 2018Initiate
Yes I've been asking them to keep me updated. They said there aware of the issue and are working on it. Hopefully that's true. I'll have to ask if they have a beta version. Thanks for the information and I'll keep you posted.
- FURRYe38Mar 20, 2018Guru - Experienced User
Good Luck.
