basic
Feb 01, 2022Aspirant
Waiting for server response when setting up VPN with Orbi on MacOS
I'm trying to connect to a VPN for work through my Orbi. I've followed the OpenVPN instructions using Tunnelbrick. When I do that I am never able to successfully connect to a server. It shows me th...
- Feb 01, 2022
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
CrimpOn
Feb 01, 2022Guru - Experienced User
OpenVPN on a home router is intended to allow the owner to access devices on the local networkk when away. i.e. to get "into" the router from the internet.
Accessing a company VPN is entirely different and may require specific VPN software and security certificates. The company IT department should be able to provide that information.
basic
The problem is that the Orbi is blocking use of any VPN and the setup instructions (https://kb.netgear.com/25389/Enabling-VPN-service-on-a-NETGEAR-router-using-a-MAC-OS-computer) have led me to this point. I'm able to use the company VPN when I'm wired in to the modem with Tunnelbrick just fine.
- FURRYe38Feb 01, 2022Guru - Experienced User
Couple of options,
