basic
Feb 01, 2022Aspirant
Waiting for server response when setting up VPN with Orbi on MacOS
I'm trying to connect to a VPN for work through my Orbi. I've followed the OpenVPN instructions using Tunnelbrick. When I do that I am never able to successfully connect to a server. It shows me th...
- Feb 01, 2022
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
basic
The problem is that the Orbi is blocking use of any VPN and the setup instructions (https://kb.netgear.com/25389/Enabling-VPN-service-on-a-NETGEAR-router-using-a-MAC-OS-computer) have led me to this point. I'm able to use the company VPN when I'm wired in to the modem with Tunnelbrick just fine.
Feb 01, 2022Guru - Experienced User
Couple of options,
