mmgala
Dec 08, 2023Aspirant
wake ove internet team viewer
Hi Im desperately trying to wake my PC over the internet when im away, and think i have seen and read most of which is out there, i'm hoping you can help. I have seen in some videos that team...
Hasnainmir
Jan 04, 2024Tutor
@mmgala wrote:Hi
I have seen in some videos that team viewer can do this, i just can't get it to work, even though i can wake the pc, when i´m on the local network, i cant using 5g
so far i have:
- reserved the pc ip on my router to a specific IP (picture)
-set up port number 9 to my pc internal ip adress (picture)
- tried 2 different DNS services (copying the DNS into wake on lan - public adress, after adding the pc to my account (teamviewer))
any good ideas
Here are few ideas to troubleshoot and improve Wake-on-LAN functionality over the internet:
i think that your router's firewall is blocking the required ports for Wake-on-LAN.ypu can check that it worked for me.
Temporarily disable any firewall or antivirus software on your PC that might be blocking external Wake-on-LAN requests. Remember to enable them again after testing.
