Getawaymike
Jul 19, 2019Follower
wall mount for RBS20
Is there a wall mount for a RBS20 satellite?
CrimpOn
Jul 19, 2019Guru - Experienced User
Amazon sells an acrylic wall mount https://www.amazon.com/Netgear-BASSTOP-Acrylic-Bracket-NETGEAR/dp/B075N6JQND/ref=sr_1_5?keywords=rbs20+wall+mount&qid=1563566374&s=gateway&sr=8-5
The advantage this has over mounting a tiny shelf is that anything pulling on the cord (cat? dog? child?) is not likely to drag it off.
There may be others as well.
