talex101
Jan 29, 2018Initiate
Wall plug satellite shows 'config sync' for backhaul status. What's that?
on the orbi status page one satellite says 'good' under backhaul status but my plugin satellite says 'config sync.' Does that mean it's connected but not very well or what? I have to say that I'm sic...
DarrenM
Feb 01, 2018Sr. NETGEAR Moderator
Config sync is just the satellite getting connection have you tried to power cycle the unit and see if it goes away?
DarrenM
- mgarruchoFeb 01, 2018Tutor
Hi DarrenM, yes. I powered it off then back on and it did went away. Now it's all good. Thanks.
- talex101Feb 03, 2018Initiate
Yep, power-cycled it numerous time, same deal.
- TactSevenFeb 09, 2018Aspirant
wrote:Config sync is just the satellite getting connection have you tried to power cycle the unit and see if it goes away?
DarrenM
Thank you DarrenM! Waiting a hours (heck it was days) did not help. Power off, PowerOn. Good.
- dmw15Feb 12, 2018Tutor
Ever since upgrading to firmware .18 this same things happens to me alot now. I, like many others are getting pretty sick of this happening especially since this expensive system is more problematic than my older and cheaper ASUS router.
- grecniMar 19, 2018Initiate
My RBR40 was at firmware V2.1.2.18, my wall plug satellite at V2.1.2.2 and I was having the same problem with the satellite staying at "config sync". I downgraded the router firmware to 2.0.0.56 and the problem went away.
