rampi
Jun 28, 2020Guide
WAN link status shows as down in AP mode
When in AP mode, the WAN link status shows as down, is that expected ?
I've connected a Cat5e cable from the Internet port on the RBR50 to the LAN port on the other ISP router.
It is all working fine but seeing slower speeds - will check more and will post separately on that.
The Internet/WAN port does become a LAN port logically in AP mode - perfectly right.
- rampiGuide
Thanks for the clarification.
But it will be good if the status gets displayed correctly as it will be useful to know what speed has been negotiated.
Anyway, thanks for the clarification.
The WAN status isn't used while AP mode thus will not be reported as online or connectred while in AP mode. Thus the display will not be used as a reporting status while in AP mode. Just look at the LAN status for your information needs.
