NGNewbie
Sep 08, 2020Star
Want to add a third RBS50 with wifi disabled
Hi, I am not exactly Networking savy so please excuse if I say any jiberish. I have a couple of devices (usually 2,4ghz only devices) that have issues connecting to the wifi network and am consi...
Mstrbig
Sep 08, 2020Master
NGNewbie wrote:
Is it a viable solution? The reason for me to disconnect the wifi of this additional satelite is to prevent interference with the existing RBR50 and RBS satelites, which would be relatively close to this new RBS50. Not sure if this would be aproblem but have read that if the units are too close there can be some handoff issues
Many thanks for your input.
Kind regards
If you don't need WIFI because you are too close to another satellite or router, is it possible to run a network cable to the area where you have these wired devices? If so run a cable and get a 5 port Netgear switch to connect your devices to.
- NGNewbieSep 08, 2020Star
Thanks. I may try to go this route in the future but right now would prefer to avoid having external personel in my living room.
But it is definitly something I am considering in the long run, notably for the added stability it provides.
Kind regards
