kcampbel44145
Jun 07, 2020Aspirant
Want to use ethernet on Multiple Orbi
I purchased the Orbi Tri-Band WIFI Whole Home Wife System. It comes with the AC3000 Router an AC3000 Satellite. I have ethernet in multiple rooms in my house and was hoping I could connect each of ...
kcampbel44145
Jun 08, 2020Aspirant
Thanks Furry. But if I don't want to use a patch panel and simply want to plug the satellite into the ethernet, it looks like I simply connect them through the ethernet to create an "ethernet backhaul connection"? It says to do so with "star topology". Can you explain what start topology is? Also, I assume I will get a faster connection than simply using the satellite wirelessly right? Thanks again
Jun 08, 2020Guru - Experienced User
You'll need to find out where the end points from the rooms go to. Yes you don't have to use a patch panel. If you know the wire from one room where you want to place the RBS and that wired goes to where the RBR is, then you can connect that wire directly to the back of the RBR. Then connect the RBS to the LAN port in the remote room you want the RBS placed in.
- kcampbel44145Jun 08, 2020Aspirant
I'm bad with the acrynoyms, not sure what RBR and RBS is but let me explain exactly how it's setup. In my basement I have the modem. From the modem I have one ethernet cable that connects directly to the main Orbi wirelss router. Then from the back of the Orbi wireless router I will have two ethernet cables going two main floor of my house and 2nd floor of my house. So the primariy orbi router is directly connected to the modem and then two additional ethernet cables are going from the router to the two wireless satellites. Does that make sense and would that give me better internet than simply running the satellite routers wirelessly?
- FURRYe38Jun 08, 2020Guru - Experienced User
You can do either.
WIreless back haul supports up to 1733Mpbs while wired supports up to 1000Mbp connect rates. Rates are only connection rates between the RBS and the RBR only. Not actual data flow speeds. WIred is more stable than wireless. Wireless can be effected by distance, noise, interference and building materials.
- kcampbel44145Jun 08, 2020AspirantOk thank you. So you would suggest wires.
