TrickyRic
Jul 24, 2020Aspirant
warning do not buy ORBI exterior melting
WARNING DO NOT PURCHASE RBK50/ AC3000 NETGEAR WILL NOT REPLACE THESE FAULTY UNITS THE EXTERIOR OF THE UNIT IS FAULTY AND DETERIORATES IN HUMID CLIMATES AND BECOME STICKY IT CAN NOT BE CLEANED ...
Retired_Member
Jul 24, 2020Yeah, it's a royal pain in the ***. Mine have been sticky roughly since a year after I bought the RBK50 combo some three years ago. Nothing much I can do about it too. Luckily they're both out of sight so I don't notice it much and they function just fine, but for the amount of money you spend it definitly should be better.
- Mikey94025Jul 25, 2020Hero
Fortunately the stickiness is only cosmetic and doesn't hamper the actual performance of your Orbi. It's a common issue with some rubber and plastic products. Here are some suggestions on how to clean sticky rubber: https://www.instructables.com/id/How-to-Clean-Sticky-Rubber/
- TrickyRicJul 25, 2020Aspirant
Well Mikey I'm guessing you work for Netgear.
You don't know what your talking and neither does the fool in the video.
You just googled it I suspect.
Its common knoweledge that alcahol actually breaks down plastic neoprene and rubber.
Unless the Orbi is made of some new material a Netgear material scientist dreamt up.?
Alcohol it not a fix it but will make the deterioration worse.
- Mikey94025Jul 26, 2020Hero
OK, but no I don't work for Netgear. Just a long-time customer of the Orbi RBR50.
