UnhappyOrbiUser
Nov 11, 2018Star
WARNING: Firmware 2.2.1.210 is junk
If you're dealing with poor WiFi performance, frequent disconnects and so on, you aren't alone, there are various other threads on this topic. Here's what you need to know:
Check if your Orbi...
Den_
Nov 16, 2018Guide
FURRYe38, is wae able to max out my 370MBit internet connection with all the previous firmwares. Nothing has changed. My satellite connection strength is showing as strong. The day I got the firmware update everything went to pot. Please stop posting the same canned response as it does not fix the problem. I rolled back the firmware and magically I now have a reliable connection again. The current firmware is terrible.
eljarviso
Nov 16, 2018Luminary
I had to roll mine back after a month. I have a SmartThings Hub hardwired into the satellite and it kept going offline. I also ran into HomeKit issues.. I couldn’t hit my HomeKit remotely.
After the rollback everything started running properly.
