UnhappyOrbiUser
Nov 11, 2018Star
WARNING: Firmware 2.2.1.210 is junk
If you're dealing with poor WiFi performance, frequent disconnects and so on, you aren't alone, there are various other threads on this topic. Here's what you need to know:
Check if your Orbi...
DickDuke
Nov 19, 2018Apprentice
I'm using Firmware 2.2.1.210 on my RBK23 (RBR20 + 2 RBS20) and have Firmware V2.2.1.204 on an RBW30. Everything is rock solid.
However, I also have a RBR40 that has Firmware 2.2.1.210 like the OP here. That unit absolutely refuses to connect to more than 2 of the 3 staellites. It appears that there may indeed be some problems with this latest firmware version on some Orbi models.I'd rather use the RBR40 because of the additional netwrok ports, but I've given up on it for now, and i'm using a 5 port switch to connect to my printer and NAS and Ethernet over powerline connection.
MY SETUP
Rogers Cable (Hitron) 200/16 > RBR20 > 2 x RBS20 + 1 x RBW30 + 5 port switch and EoP hardwired devices
Nov 19, 2018Guru - Experienced User
Possible you have bad HW with the 40 series.
You can always add more ports with a LAN switch behind the current router.
MY SETUP
